heartbeat fail // cannot connect
  • me2017
    • Apr 2017
    • 34
    I'm not finding much detail as to what this means exactly, or if it requires remediation...
    Upon stop/start/restart of agent (eg, systemctl restart zabbix-agent2) I see this in the logs:
    2023/12/11 08:08:38.885244 Plugin communication protocol version is 6.2.7
    2023/12/11 08:08:38.885266 Zabbix Agent2 hostname: [ssh02]
    2023/12/11 08:08:42.887683 [101] cannot connect to [florax.somewhere.io:10051]: dial tcp :0->192.168.1.25:10051: i/o timeout
    2023/12/11 08:08:42.887708 [101] active check configuration update from host [ssh02] started to fail
    2023/12/11 08:08:45.888858 [101] cannot connect to [florax.somewhere.io:10051]: dial tcp :0->192.168.1.25:10051: i/o timeout
    2023/12/11 08:08:45.889099 [101] sending of heartbeat message for [ssh02] started to fail
    It isn't clear to me if there's a silent recovery from this because my troubleshooting and other observations show that everything is fine:
    - I'm able to connect from the agent to the zabbix server on the specified port
    - I've verified the specified port is listening on the server
    - tcpdump on the server shows connections being made to the specified port
    - status and availability on all hosts, including the one noted here is enabled, green, and happy
    - no problems are reported on the zabbix server
    I'd like to know the following:
    - what is a hearbeat message?
    - is there some other means I can make this connection to determine the message is not currently valid?
    - is the recovery silent (not written to log)?
