zabbix-agent2 doesn't start after boot
  • m4km1k
    • Oct 2023
    After reboot zabbix-agent doesn't start:
    HTML Code:
    # systemctl status zabbix-agent2
    zabbix-agent2.service - Zabbix Agent 2
    Loaded: loaded (/usr/lib/systemd/system/zabbix-agent2.service, enabled)
    Active: inactive (dead)​
    Each time I have to:
    PHP Code:
    service start zabbix-agent2
    I have on docker on mariadb agent2.
    I've check systemctl and it's enable
    PHP Code:
    root@db1:/etc/systemd/system# systemctl is-enabled zabbix-agent2
    enabled
    when i try to manually stop and start its hangs up.
    PHP Code:
    systemctl stop zabbix-agent2
    systemctl start zabbix
    -agent2
    There's nothing interesting in log.
    When I run this:
    PHP Code:
    # update-rc.d zabbix-agent2 defaults 99
    # update-rc.d zabbix-agent2 start 99 2 3 4 5 . stop 5 0 1 6 .
    update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults​​
    Could you give me a hint where to find some log's or what to configure?
