Why dont have latest data while choose dont keep history
  • bab
    • Aug 2020
    • 194
    I am getting follow output from my prometheus metric by http
    HTML Code:
    # HELP jvm_buffer_count_buffers An estimate of the number of buffers in the pool
    # TYPE jvm_buffer_count_buffers gauge
    jvm_buffer_count_buffers{id="direct",} 33.0
    jvm_buffer_count_buffers{id="mapped",} 0.0
    # HELP zipkin_reporter_messages_total Messages reported (or attempted to be reported)
    # TYPE zipkin_reporter_messages_total counter
    zipkin_reporter_messages_total 0.0
    # HELP process_uptime_seconds The uptime of the Java virtual machine
    # TYPE process_uptime_seconds gauge
    process_uptime_seconds 1.0610442367E7
    # HELP jvm_classes_loaded_classes The number of classes that are currently loaded in the Java virtual machine
    # TYPE jvm_classes_loaded_classes gauge
    jvm_classes_loaded_classes 130821.0
    # HELP jvm_gc_max_data_size_bytes Max size of old generation memory pool
    # TYPE jvm_gc_max_data_size_bytes gauge
    jvm_gc_max_data_size_bytes 3.579314176E9
    # HELP jvm_memory_committed_bytes The amount of memory in bytes that is committed for the Java virtual machine to use
    # TYPE jvm_memory_committed_bytes gauge
    jvm_memory_committed_bytes{area="heap",id="PS Survivor Space",} 2.3068672E7
    jvm_memory_committed_bytes{area="heap",id="PS Old Gen",} 3.579314176E9
    jvm_memory_committed_bytes{area="heap",id="PS Eden Space",} 1.37887744E9
    jvm_memory_committed_bytes{area="nonheap",id="Metaspace",} 7.8936064E8
    jvm_memory_committed_bytes{area="nonheap",id="Code Cache",} 1.94248704E8
    jvm_memory_committed_bytes{area="nonheap",id="Compressed Class Space",} 1.08658688E8
    # HELP system_cpu_usage The "recent cpu usage" for the whole system
    # TYPE system_cpu_usage gauge
    system_cpu_usage 0.06215528213831141
    # HELP zipkin_reporter_spans_total Spans reported
    # TYPE zipkin_reporter_spans_total counter
    zipkin_reporter_spans_total 0.0
    # HELP jvm_threads_peak_threads The peak live thread count since the Java virtual machine started or peak was reset
    # TYPE jvm_threads_peak_threads gauge
    jvm_threads_peak_threads 95.0
    # HELP jvm_gc_memory_promoted_bytes_total Count of positive increases in the size of the old generation memory pool before GC to after GC
    # TYPE jvm_gc_memory_promoted_bytes_total counter
    jvm_gc_memory_promoted_bytes_total 1.41940352E8
    # HELP jvm_buffer_total_capacity_bytes An estimate of the total capacity of the buffers in this pool
    # TYPE jvm_buffer_total_capacity_bytes gauge
    jvm_buffer_total_capacity_bytes{id="direct",} 449226.0
    jvm_buffer_total_capacity_bytes{id="mapped",} 0.0
    # HELP zipkin_reporter_spans_dropped_total Spans dropped (failed to report)
    # TYPE zipkin_reporter_spans_dropped_total counter
    zipkin_reporter_spans_dropped_total 0.0
    # HELP method_counted_total
    # TYPE method_counted_total counter
    method_counted_total{class="com.dsa.baas.controller.LoanController",exception="ProcedureExecutionException",method="createAndDisburseLoanAccountNonInstallment",result="failure",} 2222.0
    method_counted_total{class="com.dsa.baas.controller.DepositController",exception="ProcedureExecutionException",method="transfer",result="failure",} 18.0
    method_counted_total{class="com.dsa.baas.controller.LoanController",exception="CbiServiceException",method="createAndDisburseLoanAccountNonInstallment",result="failure",} 933.0
    method_counted_total{class="com.dsa.baas.controller.CustomerController",exception="none",method="customerDetailsInquiry",result="success",} 114.0
    method_counted_total{class="com.dsa.baas.controller.AccountController",exception="none",method="createAccount",result="success",} 20.0
    method_counted_total{class="com.dsa.baas.controller.LoanController",exception="none",method="createAndDisburseLoanAccountNonInstallment",result="success",} 1215.0
    method_counted_total{class="com.dsa.baas.controller.DepositController",exception="none",method="transfer",result="success",} 2369.0
    method_counted_total{class="com.dsa.baas.controller.AccountController",exception="none",method="addSignature",result="success",} 20.0
    method_counted_total{class="com.dsa.baas.controller.CustomerController",exception="ResourceNotFoundException",method="customerInquiry",result="failure",} 183.0
    method_counted_total{class="com.dsa.baas.controller.AccountController",exception="none",method="invoiceDiscounting",result="success",} 20.0
    method_counted_total{class="com.dsa.baas.controller.CustomerController",exception="none",method="createCustomer",result="success",} 12.0
    method_counted_total{class="com.dsa.baas.controller.CustomerController",exception="none",method="customerInquiry",result="success",} 150.0
    # HELP jvm_memory_used_bytes The amount of used memory
    # TYPE jvm_memory_used_bytes gauge​
    But I nee to create dependent item from this So I don't need above result to keep on my zabbix database so I have choosen "Do not keep history" for History storage period but it dos not get latest data but when we choose Storage Period it works and show latest data although we don't need above data . what should I do now ?
