I basically need to forward critical alerts to the NBI from Zabbix server. How do I achieve this?
Is there any simple way to achieve this?
Pardon my oversight if any, I am a begginner in zabbix.
I was able to install and configure zabbix to receive SNMP traps, I am currently using SNMPTT integrated with SNMP perl trapper. Now I need to configure zabbix in a way that it forwards all the selfmonitoring data to the external EMS (Element management system). Also how do I use the Linux System related MIBs to monitor?
There can be two option
1. either send all the self monitoring data to the NBI in a time interval or
2. only send alarms to the NBI when a certain threshold is reached. (For example, Disk utilization is more than 80%)
Sending SNMP traps to upstream systems is not well documented but can also be done by configuring a Notifications mechanism when Zabbix detects an event.
a. Configure a new media type (Adminstration, Media types tab). Media types are one of the following (E-mail, SMS, Jabber, Ez Texting & Custom alertscripts). Custom script media type can define a script which will invoke the 3rd party snmptrap binary which is included in the net-snmp-utils package. The script you write needs to be placed on the zabbix server in: /usr/lib/zabbix/alertscripts
b. Step 2 requires linking the media type with an Action delivery mechanism (Configuration, Action). You can configure what actions to report to each media type and what condition will trigger sending a message. The Actions allows sending both a Trigger message and a Recovery/Clear message. The default message provides the following fields but I believe we could tailor these to match our current MCAS SNMP events as well.
Trigger: {TRIGGER.NAME}
Trigger status: {TRIGGER.STATUS}
Trigger severity: {TRIGGER.SEVERITY}
Trigger URL: {TRIGGER.URL}
Item values:
1. {ITEM.NAME1} ({HOST.NAME1}:
But here my question is how do I create a custom script in order to send out snmptraps for these triggers? Is it possible to define a general operation which will be applicable for all the triggers? (I created multiple triggers and defined an action also a custom script to the media type.)
How do I send something like the following for each triggers through my custom script?
snmptrap -v 1 -c public 10.10.0.1 '.1.3.6.1.6.3.1.1.5.4' '0.0.0.0' 6 33 '55' .1.3.6.1.6.3.1.1.5.4 s "eth0"
Any Help on this will be appreciated.
Item values:
