Adjusted Regular expressions but still receiving problem notifications
  • chickenstock
    • Jan 2024
    Zabbix 6.0
    I remove something from here:
    Administration -> General -> regular expressions
    HTML Code:
    ^(BITS|WpnUserService.*|cbdhsvc_.*|DoSvc|MapsBroke r)$
    I removed BITS|
    ​But Monitoring->Problems still show up with regard to the service. What is left to do to stop problems being raised for services I remove from regular expressions?
  • chickenstock
    • Jan 2024
    I went to Templates -> and BOTH
    Windows services by Zabbix agent​
    Windows services by Zabbix agent active​
    -> Discovery Rules -> Windows services discovery -> Trigger prototypes -> Expression and added exclusions there. Deleted host Problem triggers and rebooted zabbix server. Problems kept coming.
    And also
    -> Discovery Rules -> Windows services discovery -> Filters and added:
    {#SERVICE.NAME} does not match ^(CDPUserSvc.*|gupdate|OneSyncSvc.*|AsusUpdateChec k|edgeupdate|DoSvc)
      • 4996
      Did you remove already created items/triggers for that service? They may be marked with yellow "!" and hovering your mouse over it may display something like "This item is not discovered any more and will be deleted in X days, Y minutes... "
      • chickenstock
        • Jan 2024
        Unfortunately I dont see anything like that and not sure which screen that would be on. Also Im now lost here. I followed the yellow line in this pic down to Filters and ...I ended up at a different view than before. Below at the bottom is a pic of where I put the filters as I described above.
        • chickenstock
          • Jan 2024
          Seems like a pretty common problem and just a thought, it shouldn't be this hard to exclude services. Like who care if MS login doesnt work in enterprise. Im out.
