Upgrade 3.0 -> 3.2 failure
  • madmage
    • Sep 2016
    We've got a LARGE environment. Our Zabbix database is 160+ GB in size. Stopped the server, upgraded to 3.2 and then started the server.
    During the database upgrade, which took a LONG TIME, it failed with:
    3116:20160921:093100.083 current database version (mandatory/optional): 03000000/03000000
    3116:20160921:093100.083 required mandatory version: 03020000
    3116:20160921:095643.410 [Z3005] query failed: [1206] The total number of locks exceeds the lock table size [insert into event_recovery (eventid,r_eventid) values (131130718,131130815) …..
    (excluded a billion values here)
    3116:20160921:095643.428 database upgrade failed
    and then zabbix restarted the server up again and started the upgrade again. Will this eventually complete or do I need to do something else to get this to work correctly?
    All our Zabbix hosts are in VMWare, and I made a snapshot before, so I was able to immediately revert, thankfully.
    thanks for the help!
  • madmage
    • Sep 2016
    So, I tried again this morning. It took two hours to do, but it did indeed finish the upgrade. Success!
