Issue with invalid second parameter trigger
  • killmasta93
    • Oct 2019
    • 45
    Hi guys i was wondering if someone could shed some light currently getting this issue using this template
    HTML Code:
    Cannot evaluate function last(/myhost/backup.userdatabasediff.mssql.status[SQLEXPRESS,mydb,{$UDBDTIME1},{$UDBDTIME2},{$UDBDTI ME3}],#1:now-0): invalid second parameter.
    was working fine with version 5.0 zabbix since update to 6.4 not sure what changed?
    • 5004
    All that second parameter part seems useless anyway...
    #1:now-0
    #1 is default anyway, so no need to mention it and now-0 seems like "no timeshitf", so why even mention it... ? just remove that part and see, if it works...
    Otherwise you may need time unit there..m,s,h,d,w
    • killmasta93
      • Oct 2019
      • 45
      Thanks for the reply, i guess my question is howcome it was working on version 5?
      so i have this in the expression of the trigger type
      last(/dotup-zabbix-template-mssql-backup/backup.userdatabasediff.mssql.status[{#SQLINSTANCENAME},{#DBNAME},{$UDBDTIME1},{$UDBDTIME2},{$UDBDTIME3}],#1:now-0)=14
      would i change it like this?
      last(/dotup-zabbix-template-mssql-backup/backup.userdatabasediff.mssql.status[{#SQLINSTANCENAME},{#DBNAME},{$UDBDTIME1},{$UDBDTIME2},{$UDBDTIME3}])=14
      but what is odd from the first code when i test it out it shows the result to true
        • 5004
        ah ok .. I see now, where that strange thing came from .. already in 5.0 template it has last(,0), which for me is weird... and then it is converted to newer format...
        your example is ok. I cannot comment on the testing part, there may be things in code for different cases... for testing and for actually using it... Maybe something left from older code here and there...
        • killmasta93
          • Oct 2019
          • 45
          thanks for the reply it seems that
          it changed from unknown to enabled , but for some odd reason not getting the triggered
            • 5004
            Considering LLD macros, it is a discovery prototype, so verify, that all the discovery has been performed and data comes in...
            • killmasta93
              • Oct 2019
              • 45
              yeah i gave up and went to the odbc mssql
