How to parse response body from SOAP to use it as input value for next SOAP call
  • reddysk
    • Jan 2024
    Dear Community,
    I would like to ask you for advise.
    I have Host using only WEB scenarios for SOAP requests.
    Using simple call with expecting response code 20x is working fine.
    But next I need parse "session ID" from the first one and use it rawdata for next call.
    And let it is not simple, response from second call I need to parse in quite complex way in order to pickup variables from XPATH and visualize them to Dashboard.
    The values represent number of active and failed instances.
    I am considering if it is possible to setup that by series of macros in Zabbix directly or I should use some dedicated agent which will parse all and submit to Zabbix DB.
    Thanks and Cheers, Rudo
    • 5008
    Web scenarios do not pull data and store them in items to display somewhere... Web scenarios test the availability of a webpage(s) and give you stats about this...
    To pull data from webpages, you should look into http agent type items...
    • Hamardaban
      • May 2019
      • 2714
      Or SCRIPT items with JS code !
