Zabbix Agent 6.4 installation issue on RHEL8
  • anderlee
    • Jan 2024
    How to resolve the below installation problem on RHEL8? thanks.
    $ cat /etc/redhat-release
    Red Hat Enterprise Linux release 8.9 (Ootpa)
    $ rpm -qa |grep zabbix
    $ sudo rpm -Uvh https://repo.zabbix.com/zabbix/6.4/r...el8.noarch.rpm
    Retrieving https://repo.zabbix.com/zabbix/6.4/r...el8.noarch.rpm
    Verifying... ################################# [100%]
    Preparing... ################################# [100%]
    Updating / installing...
    1:zabbix-release-6.4-1.el8 ################################# [100%]
    $ sudo dnf install zabbix-agent
    Updating Subscription Management repositories.
    Red Hat Enterprise Linux 7 Server from RHUI (RPMs) 36 B/s | 272 B 00:07
    Errors during downloading metadata for repository 'rhel-7-server-rhui-rpms':
    - Status code: 404 for https://rhui-2.microsoft.com/pulp/re...ata/repomd.xml (IP: 40.85.190.91)
    - Status code: 404 for https://rhui-3.microsoft.com/pulp/re...ata/repomd.xml (IP: 40.85.190.91)
    - Status code: 404 for https://rhui-1.microsoft.com/pulp/re...ata/repomd.xml (IP: 40.85.190.91)
    Error: Failed to download metadata for repo 'rhel-7-server-rhui-rpms': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
    zabbix-release-6.4-1.el8.noarch
    • 5004
    You have redhat 8 and you try to update somekind of redhat 7 repos? Nothing to do with zabbix agent install, as it seems to be installed in the end...
