Global macro update with API
  • markfree
    • Apr 2019
    • 875
    Zabbix 6.2
    Hey guys.
    I'm trying to update a global macro using the Zabbix API.
    For testing, I used the "usermacro.updateglobal" method.
    The script:
    #!/bin/bash
    # Zabbix Auth
    ZABBIX_URL="https://zabbix.url/api_jsonrpc.php"
    ZBXTOKEN="zabbix_api_token"
    # Global Macro ID to update
    GMACROID_1="4"
    GMACROID_2="5"
    GMACROID_3="6"
    # Datas
    DATA1=$(data 1)
    DATA2=$(data 2)
    DATA3=$(data 3)
    # Zabbix API payload
    PAYLOAD='{
            "jsonrpc": "2.0",
            "method": "usermacro.updateglobal",
            "params": [{
                    "globalmacroid": "'"${GMACROID_1}"'",
                    "value": "'"${DATA1}"'"
                    "globalmacroid": "'"${GMACROID_2}"'",
                    "value": "'"${DATA2}"'"
                    "globalmacroid": "'"${GMACROID_3}"'",
                    "value": "'"${DATA3}"'"
            "auth": "'"$ZBXTOKEN"'",
            "id": 2
    echo -e "PAYLOAD\n $PAYLOAD"
    # Curl response
    RESPONSE="$(curl --silent -k \
            --show-error \
            --request POST \
            --header "Content-Type: application/json" \
            --data "${PAYLOAD}" \
            --url $ZABBIX_URL)"
    echo -e "\n\nRESPONSE\n $RESPONSE"
    # Erro check
    ERROR=$(echo "${RESPONSE}" | jq -r '.error.message')
    if [ "${ERROR}" != "null" ]; then
            echo -e "\nError Zabbix API:"
            echo "${ERROR}"
            exit 1
    fi
    The actual payload.
      "jsonrpc": "2.0",
      "params": [{
          "globalmacroid": "4",
          "value": "1"
          "globalmacroid": "5",
          "value": "2"
          "globalmacroid": "6",
          "value": "3"
      "auth": "1122334455",
      "id": 2
    The issue is that the "usermacro.updateglobal" JSON response is an error.
    {"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"No permissions to call \"usermacro.updateglobal\"."},"id":2}
    For the "event.acknowledge" method, the requests have no issues, but the same is not true for the​ "usermacro.updateglobal".
    The API user role has the "event.acknowledge" and "usermacro.*" permissions. (there's no "usermacro.updateglobal" available on the list).
    Click image for larger version  Name:	image.png Views:	0 Size:	21.2 KB ID:	477249​
    I'm not sure if the issue is related to permissions or an invalid parameter.
    Any thoughts?​
  • Answer selected by markfree at 17-01-2024, 18:20.
    cyber
    • 4996
    https://www.zabbix.com/documentation...ermacro/update
    This method is only available to Admin and Super admin user types.​
    if you change role type from user to admin (you do not even have to save changes) you get also other usermacro. methods in allow list, if you start typing them...
    • markfree
      markfree commented
      It was permissions after all. Thanks, buddy.
    • 4996
    • markfree
      markfree commented
