built zabbix-7.0.0alpha9 on Centos7.9 error
  • coffee
    • Oct 2021
    • 15
    Hi, I built zabbix-7.0.0alpha9 on Centos7.9 and encountered the following error, which seems to be related to net snmp. However, I have already installed net snmp, which is version 5.7.2-49.el7_ 9.3. x86_ 64, please help me.
    make error:
    checks_snmp.c: In function ‘asynch_response’:
    checks_snmp.c:2285:8: error: ‘NETSNMP_CALLBACK_OP_SEC_ERROR’ undeclared (first use in this function)
    case NETSNMP_CALLBACK_OP_SEC_ERROR:
    checks_snmp.c:2285:8: note: each undeclared identifier is reported only once for each function it appears in
    checks_snmp.c:2289:8: error: ‘NETSNMP_CALLBACK_OP_RESEND’ undeclared (first use in this function)
    case NETSNMP_CALLBACK_OP_RESEND:
    checks_snmp.c: In function ‘get_values_snmp’:
    checks_snmp.c:3198:59: error: ‘EVDNS_BASE_INITIALIZE_NAMESERVERS’ undeclared (first use in this function)
    if (NULL == (dnsbase = evdns_base_new(snmp_result.base, EVDNS_BASE_INITIALIZE_NAMESERVERS)))
    make[3]: *** [libzbxpoller_a-checks_snmp.o] Error 1
    make[3]: *** Waiting for unfinished jobs....
    mv -f .deps/libzbxpoller_a-checks_simple_vmware.Tpo .deps/libzbxpoller_a-checks_simple_vmware.Po
    make[3]: Leaving directory `/root/zabbix-7.0.0alpha9/src/zabbix_server/poller'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/root/zabbix-7.0.0alpha9/src/zabbix_server'
    make[1]: *** [all-recursive] Error 1
    make[1]: Leaving directory `/root/zabbix-7.0.0alpha9/src'
    make: *** [all-recursive] Error 1​
  • Answer selected by coffee at 19-01-2024, 10:44.
    coffee
    • Oct 2021
    • 15
    Solved, the low versions of libevent and net snmp caused it. I upgraded to libevent-2.1.12 and net snmp 5.9.4 to resolve the issue.
    • coffee
      • Oct 2021
      • 15
      The net snmp related component packages are as follows.
      • coffee
        • Oct 2021
        • 15
