I have older zabbix proxy (zabbix v3 - redhat 7 - sqlite 3) that I recently reinstalled the zabbix proxy software on. Everything seems to run fine as it connects to the zabbix server and all data is flowing. However on monthly reboots the proxy server seems to start but does not reconnect to the zabbix server. I am guessing it is not fully started even though systemctl says proxy service is running. I have to stop the zabbix proxy service, delete proxy DB file then restart the proxy and it is fine again. Just wondering where to look before I attempt to rebuild it all again.
1296:20240123:133902.205 Starting Zabbix Proxy (active) [xxxxxxxxx]. Zabbix 3.0.30 (revision f25037a887).
1296:20240123:133902.221 **** Enabled features ****
1296:20240123:133902.221 SNMP monitoring: YES
1296:20240123:133902.221 IPMI monitoring: YES
1296:20240123:133902.222 Web monitoring: YES
1296:20240123:133902.222 VMware monitoring: YES
1296:20240123:133902.222 ODBC: YES
1296:20240123:133902.222 SSH2 support: YES
1296:20240123:133902.222 IPv6 support: YES
1296:20240123:133902.222 TLS support: YES
1296:20240123:133902.222 **************************
1296:20240123:133902.222 using configuration file: /etc/zabbix/zabbix_proxy.conf
1296:20240123:133902.289 current database version (mandatory/optional): 03000000/03000000
1296:20240123:133902.289 required mandatory version: 03000000
