6.0.25: ftp item check failed with Protocol ftp not supported or disabled in libcurl
  • OGER
    • Jan 2024
    Since upgrade zabbix-server from 6.0.9 on debian 11 to 6.0.25. All my web scenarios item doing FTP url chek no longer works and send me the error :
    Protocol "ftp" not supported or disabled in libcurl
    All those ftp check items in web were working fine in 6.0.9 .
    I configured the web items like this :
Name:	Capture d’écran 2024-01-24 à 12.47.31.png
    using a standard url check : ftp://login[email protected] and checking that the result status code is 226.
    Those items no longer work as you see below :
Name:	Capture d’écran 2024-01-24 à 12.46.48.png
    For info, the libcurl package installed are those one :
    # dpkg -l | grep libcurl
    ii libcurl3-gnutls:amd64 7.74.0-1.3+deb11u11 amd64 easy-to-use client-side URL transfer library (GnuTLS flavour)
    ii libcurl4:amd64 7.74.0-1.3+deb11u11 amd64 easy-to-use client-side URL transfer library (OpenSSL flavour)
    ii python3-pycurl 7.43.0.6-5 amd64 Python bindings to libcurl (Python 3)​
    Thanks in advance for your support.
    tony
