Postgres database upgrade failed
  • MuRo
    • Nov 2022
    Hi everyone,
    I have a Zabbix server with Docker container and upgraded from version 6.0.4 to 6.4.10 following the procedure
    - stop container
    - remove container
    - start container with previous paameters
    But I receive this error:
    Starting Zabbix Server. Zabbix 6.4.10 (revision 4da16fb).
    Press Ctrl+C to exit.
    8:20240124:115320.607 Starting Zabbix Server. Zabbix 6.4.10 (revision 4da16fb).
    8:20240124:115320.607 ****** Enabled features ******
    8:20240124:115320.607 SNMP monitoring: YES
    8:20240124:115320.607 IPMI monitoring: YES
    8:20240124:115320.607 Web monitoring: YES
    8:20240124:115320.608 VMware monitoring: YES
    8:20240124:115320.608 SMTP authentication: YES
    8:20240124:115320.608 ODBC: YES
    8:20240124:115320.608 SSH support: YES
    8:20240124:115320.608 IPv6 support: YES
    8:20240124:115320.608 TLS support: YES
    8:20240124:115320.608 ******************************
    8:20240124:115320.608 using configuration file: /etc/zabbix/zabbix_server.conf
    8:20240124:115320.724 current database version (mandatory/optional): 06010005/06010005
    8:20240124:115320.724 required mandatory version: 06040000
    8:20240124:115320.724 mandatory patches were found
    8:20240124:115320.728 starting automatic database upgrade
    8:20240124:115320.729 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "userdirectory" already exists
    [create table userdirectory (
    userdirectoryid bigint not null,
    name varchar(128) default '' not null,
    description text default '' not null,
    host varchar(255) default '' not null,
    port integer default '389' not null,
    base_dn varchar(255) default '' not null,
    bind_dn varchar(255) default '' not null,
    bind_password varchar(128) default '' not null,
    search_attribute varchar(128) default '' not null,
    start_tls integer default '0' not null,
    search_filter varchar(255) default '' not null,
    primary key (userdirectoryid)
    8:20240124:115320.729 database upgrade failed on patch 06010006, exiting in 10 seconds
    8:20240124:115330.730 Zabbix Server stopped. Zabbix 6.4.10 (revision 4da16fb).
    The following are the env of my zabbix-server container
    env:
    DB_SERVER_HOST: 'postgres'
    DB_SERVER_PORT: '5432'
    DB_SERVER_SCHEMA: 'zabbix-server'
    POSTGRES_DB: 'zabbix-server'
    POSTGRES_USER: 'admin'
    POSTGRES_PASSWORD: '{{POSTGRES_PASSWORD}}'
    And these are those of the postgres container
    env:
    POSTGRES_USER: admin
    POSTGRES_DB: zabbix-server
    ZBX_HOSTNAME: "Zabbix server"
    I tried to manual deleting the relation "userdirectory" but without succes.
    Can you help me, please?
    Thanks in advance!​
