i create a item name "Logins not autorize" [ with the key S12 taken from MRTGEXT software ] to monitor wether it's possible or not to login on a netware server.
That item has been created inside a template.
Each Novell server belong to that template.
I create then a trigger named "{HOSTNAME}: logins not autorize" on that item.
when the trigger get ON, i get an entry in the Monitoring->Triggers menu with the GOOD server name
now i create an action on that trigger to get warn by email.
It's a very generic action as it take alls the triggers with severity >= "warning" and value="ON".
i well receive the mail, BUT instead of getting the name of the server, the macro { HOSTNAME} is not replace ...
What's wrong ??
thanks
What's wrong ??
thanks
