Graphs in error after switch MongoDB work in cluster mode Replica Set
  • studero
    • Aug 2023
    • 85
    Hi all,
    I have create a MongoDB cluster with 3 nodes with using the Replica Set.
    I have configured Zabbix with using the template "MongoDB node by Zabbix agent 2" to monitor each nodes. That's work fine.
    Then I have made many switch to activate another node as primary server. But now, I have some errors to monitor some items on the 3 nodes.
    The all following item say " Timeout" error
    - MongoDB: Memory: mapped
    - MongoDB: Preload docs, rate
    - MongoDB db_history_update.coll_flutter: Capped: max size
    - MongoDB testDB: Get db stats testDB
    And some other items.
    And the zabbix-server log say:
    1345:20240130:165507.544 error reason for "svx---.ch:mongodb.rs.total_nodes[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630100, "I" :5},"signature":{"hash":{"Subtype":0,"Data":"Io...
    1. Failed: cannot extract value from json by path "$.members[?(@.self == "true")].totalNodes.first()": no data matches the specified path
    1345:20240130:165507.559 error reason for "svx---.ch:mongodb.rs.unhealthy_count[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630100, "I" :5},"signature":{"hash":{"Subtype":0,"Data":"Io...
    1. Failed: cannot extract value from json by path "$.members[?(@.self == "true")].unhealthyCount.first()": no data matches the specified path
    1343:20240130:165518.586 error reason for "svx---.ch:mongodb.wired_tiger.cache.max_page_size_evicti on[]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630117, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"iL...
    1. Failed: cannot extract value from json by path "$.wiredTiger.cache['maximum page size at eviction']": no data matches the specified path
    1345:20240130:165526.604 error reason for "svx---.ch:mongodb.rs.unhealthy[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630117, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"iL...
    1. Failed: cannot extract value from json by path "$.members[?(@.self == "true")].unhealthyNodes.first()": no data matches the specified path
    1345:20240130:165526.604 error reason for "svx---ch:mongodb.rs.total_nodes[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630117, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"iL...
    1345:20240130:165526.612 error reason for "svx---.ch:mongodb.rs.unhealthy_count[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630117, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"iL...
    1344:20240130:165606.691 error reason for "svx---.ch:mongodb.rs.unhealthy[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630157, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"0A...
    1344:20240130:165606.691 error reason for "svx---.ch:mongodb.rs.total_nodes[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630157, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"0A...
    1344:20240130:165606.708 error reason for "svx---.ch:mongodb.rs.unhealthy_count[ReplicaMGDB]" changed: Preprocessing failed for: {"$clusterTime":{"clusterTime":{"T":1706630157, "I" :1},"signature":{"hash":{"Subtype":0,"Data":"0A...
    1. Failed: cannot extract value from json by path "$.members[?(@.self == "true")].unhealthyCount.first()": no data matches the specified path​
    I need help
    Regards
    Olivier
  • studero
    • Aug 2023
    • 85
    Hi guys,
    I need help !!!
    Please
