lld via json
  • xristoskon
    • Feb 2024
    lld via json
    I have created the following json :
    HTML Code:
      "data": [
          "NAME": "name1"
          "NAME": "name2"
          "NAME": "name3"
          "NAME": "name4"
    }  zz0.tk4j62yykvdzz
    and i have the following in the lld macro
    {#NAME} -> (json path) $.data.*.*
    At item prototype i have
    Name {NAME}
    key: test.greplogtime[{NAME}] # custom item
    what am i doing wrong?
  • Answer selected by xristoskon at 05-02-2024, 15:39.
    Hamardaban
    • May 2019
    • 2714
    Describe the macro like this and value will be without square brackets
    {#NAME} -> (json path) $.NAME
      • 4996
      IIRC... (those jsonpaths always screw my head up.. )
      {#NAME} -> (json path) $.data.NAME or $..NAME
      and in prototype use also {#NAME}​
      • xristoskon
        • Feb 2024
        finally , something worked. but i have an issue with the items created
        i use item prototype name: {#NAME}
        and one item that is created (for example) has name ["name1"] , how am i supposted to strip 2 characters from left and 2 from right
        • xristoskon
          • Feb 2024
          and one item that is created (for example) has name ["name1"] , how am i supposted to strip 2 characters from left and 2 from right​
          • Hamardaban
            • May 2019
            • 2714
            • xristoskon
              • Feb 2024
              thank you it worked
