Problem with Zabbix performance - History syncer processes 100%
  • gcaselli
    • Oct 2022
    Hi all,
    I'm in the process of setting up a new Zabbix environment. This Zabbix instance is containerized within Azure Kubernetes Services (AKS), currently monitoring 249 hosts and 32,928 items, with 6 proxies in operation.
    However, I'm encountering an issue where the process history syncer consistently hits 100%, causing a slowdown in monitoring. Interestingly, restarting the container temporarily resolves the issue, but it resurfaces after a while.
    Here are some additional details:
    • Zabbix Backend and Frontend are containerized in AKS, running version 6.4.10.
    • The database is also containerized in AKS, using MariaDB 11.0.3 managed via Kubernetes Operators for MariaDB. Kubernetes Operators for MariaDB - MariaDB Knowledge Base​
    • Zabbix Proxies are installed on-premise K3S clusters, also running version 6.4.10.
    System Information:
    Number of hosts 249
    Number of items 32928
    Number of triggers 19228
    Required server perf 371.29
    Zabbix Backend non default values:
    ​- ZBX_HISTORYSTORAGEDATEINDEX: "1"
    - ZBX_STARTREPORTWRITERS: "3"
    - ZBX_DEBUGLEVEL: "3"
    - ZBX_JAVAGATEWAY_ENABLE: "false"
    - ZBX_ENABLE_SNMP_TRAPS: "true"
    - ZBX_CACHESIZE: "512M"
    - ZBX_VALUECACHESIZE: "512M"
    - ZBX_HISTORYCACHESIZE: "128M"
    - ZBX_HISTORYINDEXCACHESIZE: "64M"
    - ZBX_STARTDBSYNCERS: "7"
    - ZBX_TIMEOUT: "4"
    - ZBX_LOGSLOWQUERIES: "3000"
    - DEBUG_MODE: "false"​
    I'm seeking advice on how to improve performance in this scenario.
    Thanks a lot!
    Best Regards,
    Gianni.
  • gcaselli
    • Oct 2022
    in AKS, Zabbix is in a kubernetes pool with 1 node, and the Database is in a pool with 2 nodes, the nodes are of size Standard_D4ds_v5 in Azure.
