Dear all,Dear all,
I installed zabbix in a docker container. Unfortunately, sometimes the container gets stuck and zabbix no longer works. So I have to restart the container to get it going again.
Inside zabbix I am monitoring websites and containers in total 169 Hosts.
I looked in the logs and I keep getting these errors:
260:20240207:145506.861 Zabbix agent item "docker.data_usage" on host "mweb04" failed: first network error, wait for 15 seconds
264:20240207:145521.349 resuming Zabbix agent checks on host "mweb04": connection restored​
can you tell me why zabbix keeps shutting down?
this is my config:
# ZBX_LISTENIP=
# ZBX_LISTENBACKLOG=
# ZBX_HISTORYSTORAGEURL=http://elasticsearch:9200/ # Available since 3.4.5
# ZBX_HISTORYSTORAGETYPES=uint,dbl,str,log,text # Available since 3.4.5
# ZBX_ALLOWUNSUPPORTEDDBVERSIONS=0 # Available since 6.0.0
# ZBX_DBTLSCONNECT=required # Available since 5.0.0
# ZBX_DBTLSCAFILE=/run/secrets/root-ca.pem # Available since 5.0.0
# ZBX_DBTLSCERTFILE=/run/secrets/client-cert.pem # Available since 5.0.0
# ZBX_DBTLSKEYFILE=/run/secrets/client-key.pem # Available since 5.0.0
# ZBX_DBTLSCIPHER= # Available since 5.0.0
# ZBX_DBTLSCIPHER13= # Available since 5.0.0
# ZBX_AUTOHANODENAME=fqdn # Allowed values: fqdn, hostname. Available since 6.0.0
# ZBX_HANODENAME= # Available since 6.0.0
# ZBX_AUTONODEADDRESS=fqdn # Allowed values: fqdn, hostname. Available since 6.0.0
# ZBX_NODEADDRESSPORT=10051 # Allowed to use with ZBX_AUTONODEADDRESS variable only. Available since 6.0.0
# ZBX_NODEADDRESS=localhost:10051 # Available since 6.0.0
# ZBX_DEBUGLEVEL=3
ZBX_STARTPOLLERS=10
# ZBX_IPMIPOLLERS=0
# ZBX_STARTPREPROCESSORS=3 # Available since 3.4.0
# ZBX_STARTCONNECTORS=0 # Available since 6.4.0
# ZBX_STARTPOLLERSUNREACHABLE=1
# ZBX_STARTTRAPPERS=5
# ZBX_STARTPINGERS=1
# ZBX_STARTDISCOVERERS=1
# ZBX_STARTODBCPOLLERS=1 # Available since 6.0.0
# ZBX_STARTHTTPPOLLERS=1
# ZBX_STARTHISTORYPOLLERS=5 # Available since 5.4.0
# ZBX_STARTTIMERS=1
# ZBX_STARTESCALATORS=1
# ZBX_STARTALERTERS=3 # Available since 3.4.0
# ZBX_STARTLLDPROCESSORS=2
ZBX_JAVAGATEWAY_ENABLE=true
# ZBX_JAVAGATEWAY=zabbix-java-gateway
# ZBX_JAVAGATEWAYPORT=10052
ZBX_STARTJAVAPOLLERS=5
# ZBX_STARTVMWARECOLLECTORS=0
# ZBX_VMWAREFREQUENCY=60
# ZBX_VMWAREPERFFREQUENCY=60
# ZBX_VMWARECACHESIZE=8M
# ZBX_VMWARETIMEOUT=10
ZBX_ENABLE_SNMP_TRAPS=true
# ZBX_SOURCEIP=
# ZBX_HOUSEKEEPINGFREQUENCY=1
# ZBX_MAXHOUSEKEEPERDELETE=5000
# ZBX_PROBLEMHOUSEKEEPINGFREQUENCY=60
ZBX_CACHESIZE=2G
# ZBX_CACHEUPDATEFREQUENCY=10
# ZBX_STARTDBSYNCERS=4
# ZBX_HISTORYCACHESIZE=16M
# ZBX_HISTORYINDEXCACHESIZE=4M
# ZBX_HISTORYSTORAGEDATEINDEX=0
ZBX_TRENDCACHESIZE=1G
# ZBX_TRENDFUNCTIONCACHESIZE=4M
ZBX_VALUECACHESIZE=32M
# ZBX_TIMEOUT=4
# ZBX_TRAPPERTIMEOUT=300
# ZBX_UNREACHABLEPERIOD=45
# ZBX_UNAVAILABLEDELAY=60
# ZBX_UNREACHABLEDELAY=15
# ZBX_LOGSLOWQUERIES=3000
# ZBX_EXPORTFILESIZE=
# ZBX_STARTPROXYPOLLERS=1
# ZBX_PROXYCONFIGFREQUENCY=10
# ZBX_PROXYDATAFREQUENCY=1
# ZBX_LOADMODULE="dummy1.so,dummy2.so,dummy10.so"
# ZBX_TLSCAFILE=
# ZBX_TLSCRLFILE=
# ZBX_TLSCERTFILE=
# ZBX_TLSKEYFILE=
# ZBX_VAULT=HashiCorp # Available since 6.2.0
# ZBX_VAULTDBPATH=
# ZBX_VAULTTLSCERTFILE= # Available since 6.2.0
# ZBX_VAULTTLSKEYFILE= # Available since 6.2.0
# ZBX_VAULTURL=https://127.0.0.1:8200
# VAULT_TOKEN=
# ZBX_STARTREPORTWRITERS=0
# ZBX_WEBSERVICEURL=http://zabbix-web-service:10053/report
# ZBX_SERVICEMANAGERSYNCFREQUENCY=60​
this is my config:
# ZBX_LISTENIP=
# ZBX_DEBUGLEVEL=3
ZBX_STARTPOLLERS=10
# ZBX_IPMIPOLLERS=0
# ZBX_STARTTIMERS=1
# ZBX_SOURCEIP=
ZBX_CACHESIZE=2G
# ZBX_TIMEOUT=4
# ZBX_TLSCAFILE=
# ZBX_TLSCRLFILE=
# ZBX_TLSCERTFILE=
# ZBX_TLSKEYFILE=
# ZBX_VAULTDBPATH=
# VAULT_TOKEN=
