Graphing problem
  • csterley
    • Jun 2023
    Graphing problem
    Adding in a few Cisco catalyst switches with the Cisco IOS by SNMP template and the data is being collected as expected. When I try to place a graph on a dashboard to show data from one of the interfaces, I'm not getting any data shown in the graph.
    Odd thing happening is when I select the host name in the data set host pattern, it will usually default to that host when I go to select the item pattern, now I have to select the host again before it shows the items. I can see the data when i look at the latest data screen and even select the option to graph it. Almost like there is a link missing somewhere, not sure what it's doing.
    I have other host checks, windows servers, that i can graph without issue, it's just the cisco switches that aren't working.
  • csterley
    • Jun 2023
    This appears to be checks that utilize SNMP type checks. The agent checks are working as they should.
    This is running on Ubuntu 22.04, DB is running on one server while everything else runs on another.
