Activating OKTA SSO
  • bdobson
    • Feb 2024
    • 19
    Activating OKTA SSO
    Hello, I have a new installation of Zabbix 6.4.11 on Ubuntu 22 installed via the directions from the installation page.
    Our administrators set up my OKTA application and I have input the data required.
    I have the idp.crt in what I believe for Ubuntu is the required directory:
    root@zabbix:/usr/share/zabbix/conf/certs# ls -lah
    total 12K
    drwxr-xr-x 2 root root 4.0K Jan 19 17:09 .
    drwxr-xr-x 3 root root 4.0K Jan 29 15:27 ..
    -rw-r--r-- 1 www-data www-data 1.3K Jan 19 00:47 idp.crt
    However, I get the dreaded "Invalid array settings: sp_certs_not_found_and_required"
    I have my SSO sign-on URL set to like this:
    However is the error not specific in that it's finding the sp_certs though I'm using SSO for OKTA and the request for idp be incorrect?
  • ogmh
    • Feb 2024
    In zabbix.conf.php have you configured those parameters ?
    $SSO['SP_KEY']
    $SSO['SP_CERT']
    $SSO['IDP_CERT']
    • bmcgoang
      • Feb 2024
      Where is this file 'zabbix.conf.php' in the docker / docker compose setup? Can't seem to find it.
      • bdobson
        • Feb 2024
        • 19
        $SSO['SP_KEY']
        $SSO['SP_CERT']
        $SSO['IDP_CERT']
        Thank you for the pointer, in mine it was in the UI I set those and had an error in the certificate I pasted from the source.
