Integration with Jira Service Desk
  • simonl
    • Apr 2021
    • 11
    Running the latest version of v6.2, trying to configure integration with Jira as per this document: https://www.zabbix.com/integrations/...ra_servicedesk
    I've configured the webhook media type and successfully tested it via the media 'Test' button. I've even been able to add a new entry to an existing Jira ticket using that Test.
    However, when I try to automatically create a ticket as an action for a new alert I get this error:
    Sending failed: Request failed with status code 400: "Unable to create request because of theses errors : The field 'description' is not valid for this request type 'System Event'." Check debug log for more information.
    When I view other 'System Event' type tickets in Jira I can see a field labelled 'description'.
    Sadly, I don't have admin rights to our (cloud-based) Jira so troubleshooting from that end is proving difficult.
  • jnsvano
    • Feb 2013
    • 144
    Probably because of permissions in particular Jira project. Try to create new project in Jira and set yourself (or whatever username you use in Zabbix webhook) as "Project Lead". If it will work, then this is permissions issue.
