Download zabbix
  • herve
    • Oct 2016
    Download zabbix
    My environment is a virtual machine with the below OS :
    Linux mongodb 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt25-2+deb8u3 (2016-07-02) x86_64 GNU/Linux
    I would like to install the distribution with the commands :
    root@mongodb /etc# wget http://repo.zabbix.com/zabbix/3.2/de...jessie_all.deb
    converted 'http://repo.zabbix.com/zabbix/3.2/debian/pool/main/z/zabbix-release/zabbix-release_3.2-1+jessie_all.deb' (ANSI_X3.4-1968) -> 'http://repo.zabbix.com/zabbix/3.2/debian/pool/main/z/zabbix-release/zabbix-release_3.2-1+jessie_all.deb' (UTF-8)
    --2016-10-11 13:59:06-- http://repo.zabbix.com/zabbix/3.2/de...jessie_all.deb
    Connecting to 10.143.49.209:3128... connected.
    Proxy request sent, awaiting response... 200 OK
    Length: 3916 (3.8K) [application/x-debian-package]
    Saving to: 'zabbix-release_3.2-1+jessie_all.deb.1'
    zabbix-release_3.2-1+jessie_all.deb.1 100%[================================================== ============================>] 3.82K --.-KB/s in 0s
    2016-10-11 13:59:06 (111 MB/s) - 'zabbix-release_3.2-1+jessie_all.deb.1' saved [3916/3916]
    dpkg -i zabbix-release_3.2-1+jessie_all.deb
    (Reading database ... 44716 files and directories currently installed.)
    Preparing to unpack zabbix-release_3.2-1+jessie_all.deb ...
    Unpacking zabbix-release (3.2-1+jessie) over (3.2-1+jessie) ...
    Setting up zabbix-release (3.2-1+jessie) ..
    apt-get update
    Fetched 83.7 kB in 47s (1781 B/s)
    W: Failed to fetch http://repo.zabbix.com/dists/jessie/...amd64/Packages 404 Not Found
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    The URL doesnt seem good. Could you help me ?
    Thanks a lot
    Best regards
  • batchenr
    • Sep 2016
    • 440
    it looks like your repository is not updated
    if you click on does links your getting to 404
    try to find more updated repo of zabbix
    • herve
      • Oct 2016
      Thanks for your answer.
      I have succeed to install it nanually with rpms.
