exclude specific data with regex
  • ltep
    • Nov 2022
    • 42
    I have setup 2 items to monitor a specific event in the eventlog.
    • item 1 : Windows event ID 4659: A handle to an object was requested with intent to delete.
      To collect Event ID 4659 this item has key: eventlog[Security,,,,^4659$,,skip]
      In the history of this item i can see all the events with Event ID 4659
    • item 2 : Windows event ID 4659: A handle to an object was requested with intent to delete. - count
      This item counts the values of item 1 for the last hour. The item type is "Calculated" and is using formula count(/SERVER/eventlog[Security,,,,^4659$,,skip],1h)
      This works fine too...
    I want to add 2 exclusions for the counting
    • when a string like ~$ exist it should not be counted
    • when a string like .tmp exist it should not be counted.
    I think i need this regeular expression: ^(?!.*(?:~\$|\.tmp)).*4659.*$
    When i change the formula in item 2 to count(/SERVER/eventlog[Security,,,,^(?!.*(?:~\$|\.tmp)).*4659.*$,,skip],1h) - the item gives error: Cannot evaluate function: item "/SERVER/eventlog[Security,,,,^(?!.*(?:~\$|\.tmp)).*4659.*$,,skip]" does not exist at "count(/SERVER/eventlog[Security,,,,^(?!.*(?:~\$|\.tmp)).*4659.*$,,skip],1h)".
    An example of theraw output of the Windows event ID 4659:
    Subject:
    Security ID: DOMAIN\user1
    Account Name: user1
    Account Domain: DOMAIN
    Logon ID: 0x6CE3928
    Object:
    Object Server: Security
    Object Type: File
    Object Name: D:\~$test.xlsx
    Handle ID: 0x0
    Process Information:
    Process ID: 0x4
    Access Request Information:
    Transaction ID: {00000000-0000-0000-0000-000000000000}
    Accesses: DELETE
    ReadAttributes
    Access Mask: 0x10080
    Privileges Used for Access Check:
    • 4996
    Your initial item is still "eventlog[Security,,,,^4659$,,skip]" ... You cannot change key of target item in calculated item like this... You need to move that regex a bit, out of item key... into function parameters.
    Your item: eventlog[Security,,,,^4659$,,skip]
    Your calculated item (I hope it works): count(/SERVER/eventlog[Security,,,,^4659$,,skip],1h,"regexp"​​,"^(?!.*(?:~\$|\.tmp)).*4659.*$")
    • ltep
      • Nov 2022
      • 42
      Hi Cyber,
      Thank you
      I think i'm still missing something...
      This is what i have:
      Item 1: eventlog[Security,,,,^4659$,,skip]
      Item 2: count(/SERVER/eventlog[Security,,,,^4659$,,skip],1h,"regexp","^(?!.*(?:~\$|\.tmp)).*4659.*$")
      It seems Item 2 stays at value 0. Even when Item 1 collected EventID 4659 from the EventLog without text string ~$ or .tmp
      • ltep
        • Nov 2022
        • 42
        Your calculated item (I hope it works): count(/SERVER/eventlog[Security,,,,^4659$,,skip],1h,"regexp"​,"^(?!.*(?:~\$|\.tmp)).*4659.*$")
        Instead of using RegEx i tried to use Preprocessing on the item which collects the Event ID 4659 log.
        The item key is eventlog[Security,,,,4659,,skip]
        This is the Preprocessing configured on the item.
Name:	2024-02-28 09_39_36-Configuration of items en nog 1 andere pagina - Werk - Microsoft​ Edge.png
        When the pattern ~$ or .tmp exists in the collected event, then the event itself is not stored in the history of the item.
        I did a few tests with testfiles having the pattern in the filename and it seems to work.
        For the counting i use item key: count(/SERVER/eventlog[Security,,,,4659,,skip],1h)
        But for some reason it shows a negative number in Change which i don't understand.
Name:	2024-02-28 09_46_51-Latest data en nog 1 andere pagina - Werk - Microsoft​ Edge.png
          • 4996
          so second to last value was 119?
          • ltep
            • Nov 2022
            • 42
            I can't confirm because i cleared the history and trends.
            But i can show the graph and raw values after the clear. I thought when counting the number only can increase?
Name:	2024-02-28 13_39_26-History [refreshed every 30 sec.] en nog 2 andere pagina's - Werk - Microsoft​ E.png
Name:	2024-02-28 13_40_00-.png
              • 4996
              Count of values in time period can differ I think... If your calculated item is calculated every minute, then this hour is sliding all the time... its 1h from that point back...
              • ltep
                • Nov 2022
                • 42
                Yes, i was thinking the same cyber... but i couldn't find it in the documentation. It's resetting the value each hour. That's why it shows a negative value change once the next hour begins...
