Media types - SMTP authentication error
  • MaelV
    • Jan 2024
    Hi everyone,
    I am facing issues with SMTP authentication on Zabbix : 7.0.0alpha9
    Installed on a Debian 12 VM on VirtualBox
    I am currently using a Exchange server for my compagny (ex-mail.biz)
    My media types settings are as below;
    Type = email
    Email provider = Generic SMTP
    SMTP server = ex-mail.biz
    SMTP server port = 587
    SMTP email = [email protected]
    SMTP helo = i am not sure about this one ( private-xx.fr / or / ex-mail.biz )
    Connection security = STARTTLS
    SSL verify peer = unchecked
    SSL verify host = checked
    Authentication = normal password
    User = [email protected]
    Password = xxxxxxxxxxx
    Debug logs = 5
    cat /var/log/zabbix/zabbix_server.log
    1094:20240111:080313.126 Starting Zabbix Server. Zabbix 7.0.0alpha9 (revision 6c4616adff7).
    1094:20240111:080313.127 ****** Enabled features ******
    1094:20240111:080313.127 SNMP monitoring: YES
    1094:20240111:080313.127 IPMI monitoring: YES
    1094:20240111:080313.127 Web monitoring: YES
    1094:20240111:080313.127 VMware monitoring: YES
    1094:20240111:080313.127 SMTP authentication: YES
    1094:20240111:080313.127 ODBC: YES
    1094:20240111:080313.127 SSH support: YES
    1094:20240111:080313.127 IPv6 support: YES
    1094:20240111:080313.127 TLS support: YES
    1094:20240111:080313.127 ******************************
    1196:20240111:090800.263 failed to send email: An authentication function returned an error
    1195:20240111:092524.894 failed to send email: An authentication function returned an error
    I found that the issue is the "@" in the username for the authentication, is there a way to "pass" the username with backslash or anything ?
    I also think that this shouldn't cause an error and should be implemented in future update.
    Thanks in advance for helping me.​
  • algues111
    • Oct 2025
    Hello MaelV !
    We also set up email alerts with an Exchange Server 2019 with Zabbix 7.4.3 and I wanted to thank you for your precious help !
    Actually, I was troubleshooting the auth failures in STARTTLS and found your post on this forum....
    We encountered the exact same issue. Fortunately we configured our Exchange Server to have our local domain by default, so it directly understood the simple user input without @domain.local...
    However, did you find any workaround to specifiy the domain in the username input !
    Thanks again and have a nice day !!
