Unlink (or Unlink and Clear) template does not work
  • SimpleRezo
    • Sep 2020
    • 19
    Hi
    I'm trying here since it looks like a bug to me (original post: https://www.zabbix.com/forum/zabbix-...late-from-host).
    When I go to an host, and try to unlink a template (same results with Unlink and clear), the page is reloaded and the template seems to have been successfully removed. If I try to remove another one, same results with both templates not showed anymore.
    But If I go to the host again, templates are still there !
    Zabbix version: 5.0.41
    Thanks for your help!
  • Answer selected by SimpleRezo at 27-02-2024, 17:17.
    tim.mooney
    • Dec 2012
    • 1436
    Did you remember to click the "Update" button for the host, after each "Unlink"?
    • tim.mooney
      • Dec 2012
      • 1436
      • SimpleRezo
        • Sep 2020
        • 19
        OK, that was the problem... My bad... but this is really a bad UX...
        • SimpleRezo
          • Sep 2020
          • 19
          The answer is... when page is reloaded, clicking on "Update" button is required to validate!
