Hide Information Triggers on Maps 3.0.3
  • Alexisalv02
    • Aug 2016
    Good day,
    i have a map with some links between sites of my company, i want to change the color of the backup link so we know when it's not in use, but the host shows a big circle and trigger problem on the map and everybody gets confused with it because it says problem on the map.
    Is there a way to disable the information triggers from showing the circle and the problem on the map but still change the color of the link if the trigger is activated?
    I'm on Zabbix 3.0.3
    Thank you.
    Best Regards.
