Create trigger for log input
  • ocarlossouza
    • Feb 2024
    • 22
    Hi, everyone.
    My condiction is:
    Item: log[/var/log/file.log,ACOMPANHAMENTO,,,skip]
    I need make a trigger that alert when this condiction (ACOMPANHAMENTO) is true
    • 5004
    nodata(/host/log[/var/log/file.log,ACOMPANHAMENTO,,,skip],5m)=0
    Fires when your item receives a value and keeps it open for 5 minutes, if no new values come in... (closes 5m after last received value)
    • ocarlossouza
      • Feb 2024
      • 22
      Thanks for answer.
      Can I deploy a argument (ITEM) to ignore case distinctions between upper and lowercase?
        • 5004
        This trigger expression only looks for data being present, it does not look what data contains.
        • ocarlossouza
          • Feb 2024
          • 22
          Regarding my question about item, I am creating a regular expression for this, it is almost ready. I will post here when finished.
          • ocarlossouza
            • Feb 2024
            • 22
            Hi, everyone.
            I just adapted my scenario and now I'm using this way: system.run[grep -i "erro de acesso memoria" /var/log/file.log]
            With this I resolved my case sensitive issue, my question: What would be the best way to generate a trigger when this data entry was captured by this item?
            • rdf.8888
              • Nov 2022
              Originally posted by ocarlossouza
              Hi, everyone.
              Você pode fazer um pre processamento em seu item, seria até melhor para seu banco e verificar em um periodo de tempo quantos 'erro de acesso' houve em um periodo de tempo.
              Você pode utilizar regex para fazer o pre processsamento, caso retorne verdadeiro a resposta seja 1 caso não a resposta é 0.
                • 5004
                Thanks for answer.
                Seems I did not understand you correctly at the time... You were asking about case sensitivity of the item.. log[/var/log/file.log,(?i)ACOMPANHAMENTO,,,skip] gives you that..
                Using grep from command line will always read full logfile and give you all matches, that you probably already picked up... So your option to trigger something is only based on change of amount of lines. It would make more sense to use "grep -ic" in that case to return number of matches instead of all matches. Or go back to zabbix built in key, use logrt.count, which also takes care of rotated logs...
                • ocarlossouza
                  • Feb 2024
                  • 22
                  My problem with querying the log is that it is case sensitive. For example, I may have the phrase: access error or Access Error, for both I need to be informed if this phrase appears. My new scenario is:
                  system.run[tail -n 1000 /var/log/file.log | grep -i "erro de acesso a memoria"]
                  With this I can understand if this happened in at least a certain number of lines.
