zabbix_traps.tmp growing infinitely
  • Tester001
    • Feb 2023
    • 10
    Dear Zabbix Community,
    I am using the following official script to relay SNMP traps to Zabbix:
    Real-time monitoring of IT components and services, such as networks, servers, VMs, applications and the cloud. - zabbix/zabbix
    I've noticed that the /tmp/zabbix_traps.tmp file is growing infinitely.
    How are you dealing with this problem in your deployments?
    Thank you in advance!
    • 5004
    Logrotate is invented loooong time ago.. https://linux.die.net/man/8/logrotate
    • Tester001
      • Feb 2023
      • 10
      cyber, would you be so kind and share a confirguration that you know works?
      The following doesn't work for me, sadly:
      HTML Code:
      logrotate /etc/logrotate.d/zabbix-traps
          /tmp/zabbix_traps.tmp {
              su root root
              daily
              notifempty
              missingok
              rotate 0
              maxsize 100000000
              compress
              delaycompress
        • 5004
        10 0 * * * /usr/sbin/logrotate -s /path/to/logrotate.status -f /path/to/logrotate.conf
        logrotate.conf
        /path/to/logfiles/*.log {
        compress
        create
        copytruncate
        daily
        dateext
        dateformat .%Y%m%d
        delaycompress
        missingok
        rotate 7
        • Tester001
          • Feb 2023
          • 10
          Thank you, Cyber!
