Issues with Zabbix proxy receiving Config
  • redteck85
    • Dec 2021
    Have a zabbix proxy setup on 6.4.12 and server on 6.4.11. After initial setup server seemed to be working properly had 1 host on it and everything was flowing properly. Attempted to add more hosts to it and started seeing the following error in the log.
    858:20240229:123306.784 received configuration data from server at "XXXX", datalen 532997
    858:20240229:123306.791 cannot process proxy onfiguration data received from server at "XXXX": unexpected field "httptest.agent"
    New hosts won't pull any data, unable to find any information on httptest.agent and nothing changed on the configurations of either proxy or server.
    • 4996
    Proxy is higher version than server... there might be a fixed bug in .12...
    at leasst one, that "might" be related...
    ZBX-23232 Fixed syncing web scenarios to proxy
    Try to upgrade server also...
    • karel_b
      • Feb 2017
      I had similar problem, similar scenario with proxy slightly newer that server.
      Fixed by update bots proxy and server to the same version 6.4.12
