Kubernetest Monitoring
  • bdobsoncdn
    • Mar 2024
    In a test installation, I had this working so I'm not sure now why I'm hitting this issue with Kubernetes monitoring.
    Zabbix: 6.4.12
    Chart: helm install -f zabbix_values.yaml zabbix zabbix-chart-6.4/zabbix-helm-chrt -n monitoring (installed 6.4.12 versions)
    Modified the values chart only with which points to the Zabbix server which has an active proxy. The ZBX_PROXYMODE is set to 0.
    - name: ZBX_SERVER_HOST
    value: "10.xx.xx.xx"
    I grabbed the secret for the service account via:
    kubectl get secret zabbix-service-account -n monitoring -o jsonpath={.data.token} | base64 -d
    and in the host entry which is checking nodes via HTTP, I modified:
    {$KUBE.API.TOKEN}
    {$KUBE.API.URL}
    However, it's not working due to this error. I don't recall at least in the past having to create permissions manually.
    176:20240301:044928.863 [ Kubernetes ] ERROR: Request failed with status code 403: {"kind":"Status","apiVersion":"v1","metadata":{ }," status":"Failure","message":"v1 "nodes" is forbidden: User "system:serviceaccount:monitoring:zabbix-service-account" cannot get resource "v1" in API group "" at the cluster scope","reason":"Forbidden","details":{"name":"nod es","kind":"v1"},"code":403}
    Service account details
    Namespace: monitoring
    Labels: app.kubernetes.io/instance=zabbix
    app.kubernetes.io/managed-by=Helm
    app.kubernetes.io/name=zabbix-helm-chrt
    app.kubernetes.io/version=6.4.6
    helm.sh/chart=zabbix-helm-chrt-1.3.4
    Annotations: meta.helm.sh/release-name: zabbix
    meta.helm.sh/release-namespace: monitoring
    Image pull secrets: <none>
    Mountable secrets: <none>
    Tokens: zabbix-service-account
    Events: <none>
  • spostma73
    • Mar 2024
    Same here, I am on Azure AKS.
    @bdobsoncdn Did you manage to solve this by now?
    Also seeing errors in de ZBX availability badge: Get value from agent failed: cannot connect to [[10.224.0.222]:10050]: [4] Interrupted system call
