after apt upgrade: database version does not match current requirements
  • fdpalma
    • Mar 2024
    Hi all,
    Please, I am facing issues with the DB auto upgrade after trying to run apt upgrade for ubuntu... From the website I get:
    • The Zabbix database version does not match current requirements. Your database version: 6050085. Required version: 6050209. Please contact your system administrator.
    Checking the zabbix log in /var/log/zabbix/zabbix_server.log I have this:
    2447:20240301:213252.549 ******************************
    2447:20240301:213252.549 using configuration file: /etc/zabbix/zabbix_server.conf
    2447:20240301:213252.567 current database version (mandatory/optional): 06050085/06050085
    2447:20240301:213252.567 required mandatory version: 06050209
    2447:20240301:213252.567 mandatory patches were found
    2447:20240301:213252.569 starting automatic database upgrade
    2447:20240301:213252.570 [Z3005] query failed: [1072] Key column 'proxyid' doesn't exist in table [create index task_2 on task (proxyid)]
    2447:20240301:213252.570 database upgrade failed on patch 06050086, exiting in 10 seconds
    2447:20240301:213302.570 Zabbix Server stopped. Zabbix 7.0.0beta1 (revision 9bc845eca94).
    Also I can observe this:
    1241:20240301:212043.416 completed 13% of database upgrade
    1241:20240301:212043.450 completed 14% of database upgrade
    1241:20240301:212043.469 completed 15% of database upgrade
    1241:20240301:212043.600 completed 16% of database upgrade
    1241:20240301:212043.631 completed 17% of database upgrade
    1241:20240301:212043.664 completed 18% of database upgrade
    1241:20240301:212043.691 completed 19% of database upgrade
    1241:20240301:212043.708 database upgrade failed on patch 06050086, exiting in 10 seconds
    I would appreciate any help. thanks.​
  • knownasdepe
    • Apr 2024
    just update your zabbix vesion to 6.5
      • 5004
      https://repo.zabbix.com/zabbix/6.5/u...u22.04_all.deb
      that is 7.0 beta actually... What seems to be already in place... But whats wrong with that upgrade, I cannot tell.. beta software... happens...
