snmp interface via api
  • neorejdv76
    • Nov 2021
    • 15
    hi,
    I am trying to create a net snmp interface on a host. I've copied the expample code from the manual and made it suitable for my environment:
    "jsonrpc": "2.0",
    "method": "hostinterface.create",
    "params": {
    "hostid": "11816",
    "main": "1",
    "type": "2",
    "useip": "1",
    "ip": "127.0.0.1",
    "dns": "",
    "port": "161",
    "details": {
    "version": "2",
    "bulk": "1"
    "auth": "spuersecret",
    "id": 1
    When i post this command i allways get a error:
    "message": "Parse error",
    "data": "Invalid JSON. An error occurred on the server while parsing the JSON text."
    So i understand that the json code is not correct, but i can't figureout what part is wrong. I've tried many thing now but nothing seems to work.
    I can create an agent interface via the api on the same host with out any troubles...... But a snmp interface keep failing.
    I'am using postman and zabbix 6.0.25.
    Any help would be appreciated
  • Answer selected by neorejdv76 at 06-03-2024, 13:54.
    cyber
    • 5004
    Does that host have any interfaces already? If it has, then "main" should be 0, I think...
    main integer Whether the interface is used as default on the host. Only one interface of some type can be set as default on a host.
    Possible values:
    0 - not default;
    1 - default.
      • 5004
      Possible values:
      0 - not default;
      1 - default.
      • neorejdv76
        • Nov 2021
        • 15
        Correct, that was the issue. Thanks!
