Oracle custom script say : Cannot fetch data: sql: expected 0 arguments, got 1.
  • studero
    • Aug 2023
    • 84
    Hi all,
    I have create a custom script to give the status of the request. But when I tried to use a parameter, the following error comes : Cannot fetch data: sql: expected 0 arguments, got 1..
    My configuration and script:
    The key of the new item :
    - oracle.custom.query[{$ORACLE.CONNSTRING},{$ORACLE.USER},{$ORACLE.PASSW ORD},{$ORACLE.SERVICE},state_of_refresh,RPAP1_1166 55369_REFRESH]
    The SQL script:
    /* state_of_refresh.sql */
    SELECT status
    FROM sys.dba_scheduler_job_log
    WHERE job_name = '&1'
    ORDER BY log_date DESC FETCH FIRST 1 ROWS ONLY;
    When I try to use the zabbix_get command on the Zabbix server, I see this error:
    [root@svx-mon-02t ~]# zabbix_get -s srv_oracle -k oracle.custom.query[tcp://srv_oracle:1521,zabbix,zabbixpwd,co1191cl,stat e_of_refresh,PAP2]
    ZBX_NOTSUPPORTED: Cannot fetch data: sql: expected 0 arguments, got 1.
    If I run the same script without give the parameter, the result was correct.
    I need help
    Regards
    Olivier
