Frontend/GUI differs after mayn upgrades
  • tomstocker
    • Jan 2024
    • 16
    Hello Zabbixers
    We did all upgrades form Zabbix 1.8 to now Zabbix 6LTS. Now the Menu is not the same on our Install compared to a fresh install.
    Our upgraded instance:
    vs a fresh install:
    is there any way to correct this?
  • Answer selected by tomstocker at 12-03-2024, 09:50.
    cyber
    • 4972
    You upgraded to 6.0LTS... That pic looks like as it should look. The "fresh install" looks like the GUI from 6.4... So you do not have same versions here...
      • 4972
      • tomstocker
        • Jan 2024
        • 16
        Ahh, I see then the change was between 6.0LTS and 6.4, thanks for the clarification.
