timescaledb.sql missing in zabbix-sql-scripts_7.0.0~beta1-4+ubuntu22.04_all.deb
  • dszabbix
    • Sep 2022
    timescaledb.sql was present in zabbix-sql-scripts_7.0.0~alpha1 through alpha7, but is no longer present in alpha8,9 or beta1. The documentation still refers to using this script to set up Zabbix to use timescaleDB :
    Are there updated instructions for how to enable timescaleDB on a fresh 7.0 installation?
    Thank you.
    • 5004
    Is there a "/usr/share/zabbix-sql-scripts/postgresql/timescaledb/schema.sql" ? At least, if looking on source package, it has moved and renamed... but identical file in alpha6 and beta1.
    ~/zabbix-7.0.0alpha6/database/postgresql/timescaledb.sql
    ~/zabbix-7.0.0beta1/database/postgresql/timescaledb/schema.sql
    • dszabbix
      • Sep 2022
      Thank you cyber and sorry for the late response (I didn't get an email notification and haven't been back here til now). Yes, schema.sql is there and works fine.
      • db100
        • Feb 2023
        • 62
        how about kubernetes and dockerfiles ? where is the schame.sql file ?
          • 5004
          you may need it only with clean install, if you upgrde, server does all required upgrade steps during first start.
          • db100
            db100 commented
            i believe a simple note in the documentation would be of great help !!
          • 5004
          • db100 commented
            Today, 10:19
          I don't know... If the script is used for "initial DB creation" and is not mentioned in upgrade notes, then why would you need to run it...
          • db100
            db100 commented
            i ended up needing the script for migrating a non timescale instance onto a timescale one, after installing timescale in postgres.
            the script was in the container but the path did not match the documented one AFAIK
          • db100
            db100 commented
            here the actual path inside the container: /usr/share/doc/zabbix-server-postgresql/timescaledb.sql which does not match whats written in the doc: https://www.zabbix.com/documentation...scaledb-schema
        • viruslab
          • Jul 2024
          which does not match whats written in the docs
          This is really confusing. I spent so many time to find this.
          Please fix this in the docs.
          • Markku
            • Sep 2018
            • 1788
            Select the text in the docs and press Ctrl/Command-Enter to submit feedback (see the footer text on any documentation page). (I don't know how to do that on touch-only devices)
            Markku
