VM CPU Detection
  • Q22
    • Jul 2016
    VM CPU Detection
    Hello there,
    I've been trying to monitor CPU usage on a virtual machine. The VM is set to use only some of the server's processors, so I've set CPU discovery with the following key: system.cpu.util[{#CPU.NUMBER}]
    Is that correct? The other day I saw a heavily loaded machine (100% cpu usage on the task manager) showing the load on Zabbix nowhere as high. Perhaps the CPUs detected are not the ones being used by the VM?
    Thank you!
  • Colttt
    • Mar 2009
    • 878
    which OS do you try to monitor?
    Debian-User
    Sorry for my bad english
    • Q22
      • Jul 2016
      Hello there,
      This one is a Windows 7 machine.
