Hi. Maybe you can help me.
I am trying to set up traps for zabbix. By now i am stuck in making snmptrapd work
If i start it manually it works, and i see traps on log file:
/usr/sbin/snmptrapd -On -Lf /var/log/snmptrapd.log
root@zabbix-test:/etc/init.d# ps -elf | grep snmptrapd
1 S root 6504 1 0 80 0 - 17045 - 16:17 ? 00:00:00 /usr/sbin/snmptrapd -On -Lf /var/log/snmptrapd.log
If i start it using init.d script:
/etc/init.d/snmptrapd start
[ ok ] Starting snmptrapd (via systemctl): snmptrapd.service.
0 S root 6551 1332 0 80 0 - 3182 - 16:19 pts/0 00:00:00 grep snmptrapd
(NO PROCESS SNMPTRAPD RUNNING AFTER THAT)
root@zabbix-test:/etc/init.d# service snmptrapd start
root@zabbix-test:/etc/init.d# service snmptrapd status
● snmptrapd.service - LSB: SNMP Trap daemon
Loaded: loaded (/etc/init.d/snmptrapd)
Active: active (exited) since Tue 2016-10-25 12:52:43 UYT; 3h 27min ago
Oct 25 12:52:43 zabbix-test snmptrapd[5800]: Starting SNMP trap services::
I guess the key in in knowing why state is active (exited). Maybe some kind of problem in my script, which i paste bellow:
#! /bin/sh
### BEGIN INIT INFO
# Provides: snmptrapd
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: SNMP Trap daemon
# Description: NET SNMP (Simple Network Management Protocol) trap daemon
### END INIT INFO
# Author: Hideki Yamane <[email protected]>
# (based on Jochen Friedrich <[email protected]>'s snmpd.init)
set -e
. /lib/lsb/init-functions
export PATH=/sbin:/usr/sbin:/bin:/usr/bin
test -x /usr/sbin/snmptrapd || exit 0
# Defaults
OLD_MIBS_DIR="/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp"
MIBS_DIR="/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf"
export MIBDIRS="$MIBS_DIR:$OLD_MIBS_DIR"
TRAPD_PID="/run/snmptrapd.pid"
#TRAPDRUN=yes
TRAPDRUN=no
#TRAPDOPTS="-On -Lsd -p $TRAPD_PID"
TRAPDOPTS="-On -Lf /var/log/snmptrapd.log -p $TRAPD_PID"
# Reads config file (will override defaults above)
[ -r /etc/default/snmptrapd ] && . /etc/default/snmptrapd
# Cd to / before starting any daemons.
cd /
case "$1" in
start)
log_daemon_msg "Starting SNMP trap services:"
if [ "$TRAPDRUN" = "yes" -a -f /etc/snmp/snmptrapd.conf ]; then
start-stop-daemon --quiet --start --oknodo --exec /usr/sbin/snmptrapd \
-- $TRAPDOPTS
log_progress_msg " snmptrapd"
fi
stop)
log_daemon_msg "Stopping SNMP trap services:"
start-stop-daemon --quiet --stop --oknodo --retry 3 --exec /usr/sbin/snmptrapd \
&& [ ! -f $TRAPD_PID ] || rm $TRAPD_PID
restart)
log_daemon_msg "Restarting SNMP trap services:"
start-stop-daemon --quiet --start --retry 3 --exec /usr/sbin/snmptrapd -- $TRAPDOPTS
fi
reload|force-reload)
log_daemon_msg "Reloading SNMP trap services:"
start-stop-daemon --quiet --stop --signal 1 \
--pidfile "$TRAPD_PID" --exec /usr/sbin/snmptrapd
fi
status)
status=0
status_of_proc /usr/sbin/snmptrapd snmptrapd || status=$?
fi
exit $status
echo "Usage: /etc/init.d/snmptrapd {start|stop|restart|reload|force-reload|status}"
exit 1
esac
exit 0
Any help or hint of how to troubleshoot this is more than welcome and thanks
#! /bin/sh
### BEGIN INIT INFO
### END INIT INFO
set -e
# Defaults
#TRAPDRUN=yes
TRAPDRUN=no
cd /
case "$1" in
start)
-- $TRAPDOPTS
fi
stop)
restart)
fi
fi
status)
status=0
fi
exit $status
exit 1
esac
exit 0
