cannot extract value from json by path "$..['SYSAUX'].used_from_max_pct.first()"
  • gima
    • Mar 2024
    I got this error on this discovery item - Tablespace Discovery.
    Failed: cannot extract value from json by path "$..['SYSAUX'].used_from_max_pct.first()": no data matches the specified path
    I'm using Zabbix 6.0 with zabbix agent 2 on Oracle DB with version >= 12.2; all the others item and triggers are working good, only this one is failing.
    Any suggestion on how to fix it? What I'm doing wrong?
  • Answer selected by gima at 19-03-2024, 14:47.
    cyber
    • 5004
    Seems it is looking for
    but your data contains "used_pct_max"
    If you fix this, does it work better?
    • gima
      • Mar 2024
      I want to provide you more information.
      Here you can see the lonely unsupported item
      I've tested the Item Oracle TBS 'SYSAUX': Get tablespaces stats and the result is good
      "SYSAUX":{
      "contents":"PERMANENT",
      "file_bytes":1635778560,
      "max_bytes":34359721984,
      "free_bytes":112263168,
      "used_bytes":1523515392,
      "used_pct_max":4.76,
      "used_file_pct":93.14,
      "status":1
      but I still get the error
      Preprocessing failed for: [{"SYSAUX":{"contents":"PERMANENT","file_bytes": 163 5778560,"max_bytes":34359721984,"free_bytes":1...
      1. Failed: cannot extract value from json by path "$..['SYSAUX'].used_from_max_pct.first()": no data matches the specified path
        • 5004
        • gima
          • Mar 2024
          Hello cyber,
          thank you very much for the correct answer.
          I've corrected the parameter in this way $..['{#TABLESPACE}'].used_pct_max.first() into the Item Prototype -> Preprocessing of the Tablespace Discovery
          After I've unlinked and relinked the Template to the host and now all the metrics are good.
          I've a lot of hosts with this Template ... how can I update the correct Preprocessing or the Tablespace Discovery to all those hosts massively?
            • 5004
            If you change it in template, it should be corrected everywhere with next run of discovery. Either new item appears or old one is updated... you could probably select also those items from all involved hosts on a config page (find it from one host, then remove host from selector, just leave item name/key) and remove all of them, then you can be sure, that new one will be created...
            • gima
              • Mar 2024
              Thank you cyber, now is all the items are fine.
