zabbix_agentd -t and zabbix_get return different values
  • demonito
    • Nov 2016
    Hi all! I use zabbix to monitor MegaCli raid state. It worked fine, but once it failed for some reasons.
    Here is the zabbix_agentd.conf:
    oradb-01:~ # cat /usr/local/etc/zabbix_agentd.conf
    PidFile=/var/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix_agentd.log
    EnableRemoteCommands=1
    Server=77.**.**.**
    ServerActive=77.**.**.**
    Hostname=oradb-1
    UserParameter=megacli.raid.state,/usr/bin/sudo /opt/MegaRAID/MegaCli/MegaCli -LDInfo -Lall -Aall | grep Optimal | wc -l
    If I try to check the value of megacli.raid.state locally, it returns 2:
    oradb-01:~ # sudo -u zabbix zabbix_agentd -t megacli.raid.state
    megacli.raid.state                            [t|2]
    But when I try to check it from zabbix server, it returns 0:
    23:00:29 terra # zabbix_get -s 192.168.168.10 -p 10050 -I 77.**.**.** -k megacli.raid.state
    0
    My /etc/suders.conf:
    Defaults targetpw    # ask for the password of the target user i.e. root
    %users ALL=(ALL) ALL # WARNING! Only use this together with 'Defaults targetpw'!
    root	ALL=(ALL) ALL
    zabbix	ALL=NOPASSWD:	/opt/MegaRAID/MegaCli/MegaCli
    All other parameters work fine.
    Well, the question is: why? And what should I check to find a reason?
