Macro is not working on script item
  • claudio_ract
    • Mar 2024
    I am trying to use a built-in macro ( {HOST.IP} or {HOST.CONN} ) in my Script Item, inside my template, but it is not working.
    Configuring my script item, i set "parameters name" as "host" and "parameter value" as {HOST.IP} but, when I test, the value of parameter "name" is literally {HOST.IP) instead something like 10.0.0.1
    Does anyone know what i am doing wrong ?
    ps.: I upload images because it is blocked in my company.
  • markfree
    • Apr 2019
    • 875
    How are you parsing the parameters in your script?
      • 4996
      Template has no host IP, so to be able to test it with a proper value, you need to enter some IP manually there. Or assign this template to a host, then open item via host config and test there... now it should take value from hosts config..
      I also managed to get similar situation (not resolved macro), when there was actually no IP for host, only name, when I "tested" directly on host... But {HOST.DNS} directly on host resolved nicely...
      • markfree
        • Apr 2019
        • 875
        With templates, you can also enter the macro value as you test the item.
