Zabbix Docker: No Agent Connection
  • CodeDaiki
    • Apr 2024
    Hey guys,
    we are currently - sort of - cleaning up our infrastructure.
    We have a ProxMox VE server running multiple VMs with both public and private IP networks.
    We have set up a Zabbix Server running on Ubuntu 22.04 in a private (10.0.0.0) network that has connections to the other VMs for monitoring purposes.
    We now try to migrate zabbix to our Docker server running Portainer CE.
    So far so gut, the Zabbix-Server is running and connected to a MariaDB, the webfrontend is running...... but we get no agent connections....
    On Portainer, we have exposed port 10051 of the zabbix-server container, and we can connect to it via telnet (10.172.2.112:10051)
    However, it still shows all agents added to the zabbix server as "unknown" (Agent Status ZBX: gray).
    Did we miss a thing? The docker containers are in a bridged network (172.17.0.0/16)
    Thank you in advance
    Kind Regards
    Daiki
  • BigSmooth
    • Jun 2023
    • 46
    Hi Daiki,
    Did you apply a template to your hosts you are trying to monitor in Zabbix UI? Do you want to monitor them in active or in passive mode?
    Regards,
    Olivier
    • CodeDaiki
      • Apr 2024
      Originally posted by BigSmooth
      Hi Daiki,
      Regards,
      Olivier
      DUH!!!!!
      Forgot to apply templates.... yeah, now it works, thanks
