Web Monitoring doesn't support nested variables
  • Olaff
    • May 2016
    Hello everybody,
    I have just recently upgraded Zabbix from 3.0.4 to 3.2.1 and I have found out that my web monitoring showed me failed services.
    This is because I was using variables such as:
    {http_root}=http://{HOST.DNS}:8080
    {https_root}=https://{HOST.DNS}:8081
    But I found out that from two URLs that you see in the image below, only the first one gives the 200. Another one shows 404.
    Can you please help me with the answer whether my previous way, how I used the web monitoring, was changed?
    Thanks.
  • Olaff
    • May 2016
    Bump
    I am sorry, but does anybody have a clue?
    It happened if only I change the web monitoring, where the first link doesn't have a custom variable, but the second one points to the custom variable with the system variable included, web monitoring started working.
    Thanks.
