Set alias name automatically during Zabbix Auto Registration
  • umapathy
    • Oct 2016
    Hi Team
    How to set alias name automatically during zabbix auto registraion action.
    Can you guide please
  • umapathy
    • Oct 2016
    Zabbix Team
    Can you guide to set alias name through agent config file.
    I use ansible to install agent and I want alias name to be a parameter.
    • batchenr
      • Sep 2016
      • 440
      i didnt understad
      • umapathy
        • Oct 2016
        I install zabbix agent and pass the zabbix server information in config file through ansible (using ansible parameters)
        I want to know if alias name (display name) can be set in config file.
        • batchenr
          • Sep 2016
          • 440
          you installed zabbix agent on anisble server ? and you want to know
          if you can change the display name ?
          • umapathy
            • Oct 2016
            If we can set agent display name in agent configuration file.
            I automated the agent installation through ansible, I want to pass display name as parameter.
            Currently Zabbix dashboard shows the hostname / IP but end user will not know what the server (zabbix agent) is.
            • batchenr
              • Sep 2016
              • 440
              you have this option at zabbix agent conf :
              ### Option: Alias
              # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
              # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
              # Different Alias keys may reference the same item key.
              # For example, to retrieve the ID of user 'zabbix':
              # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.[0-9]+),,,,\1]
              # Now shorthand key zabbix.userid may be used to retrieve data.
              # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
              # Mandatory: no
              # Range:
              # Default:
              im sorry i dont seem to have the knowledge that you need , i never used anisble
