Zabbix 6.4.13 with TimescaleDB backup, help me please
  • intense
    • Nov 2023
    • 18
    I have Zabbix 6.4.13 with TimescaleDB on PostgreSQL 16.
    Will backup via pg_dump be ok?
    pg_dump --no-owner -h localhost -p 5432 -U zabbix zabbix > /backup/file.sql
    When using TimescaleDB, do I have to do it differently?
    Maybe someone has a proven script?
    • 4996
    pg_dump and pg_restore should do the trick for you...
    • intense
      • Nov 2023
      • 18
      Ok thanks for answer
      • dieselfluxcapacitor
        • Jul 2023
        • 11
        intense did using
        pg_dump
        work for you? What did your command invocation look like to backup and restore the database?
        I am attempting to migrate to a new PostgreSQL 16 server from PostgreSQL 15 and can't get the data to import properly without a storm of errors. I am also using TimescaleDB
