Running Zabbix 3.2.1 server with proxies at two sites. Those two sites each have their own VMware clusters with VCenters. When I apply the VMware template to one site's VCenter, it works great, everything is discovered and shows up. When I apply it to the second site it mostly works, but the Hypervisor host discovery gets an error that it can't create the discovered hosts because the name already exists. The discovery template is making the name based on the UUID that comes back from VCenter it seems, and that UUID name is the same at both of our sites.
However, if I log on to each esx host and run "esxcli system uuid get" the UUID that gets returned is not even close to what Zabbix is saying, and they are not duplicates between the two sites. I tried appending {$HV.NAME} to the UUID just so they would get created without conflict but that causes problems later because the hypervisor checks require the UUID and that name field is where Zabbix is storing it, so all the items fail.
Does VCenter make its own UUID's different from the standalone esx host?
Does anyone know the API request Zabbix is making to get the UUID to come back?
Is there a way to change the UUID that VCenter is using/reporting on a host?
Or any other suggestions?
