New Regular Expression Error with logrt
  • David Otero
    • Apr 2024
    I've been using the following regular expression in logrt to specify the log file without any issues for several weeks:
    logrt[C:\Programas\3. Version DEBUG PalStats con Grafico\Logs\Actual\^\d{4}-\d{2}-\d{2}_\d{2}-\d{2}-\d{2}\.log,"ERROR",,,"skip",]
    However, today, unexpectedly, I encountered an error with this item stating:
    "Cannot compile a regular expression describing filename pattern: PCRE2 does not support \F, \L, \l, \N{name}, \U, or \u, position 39, flags:0x2400".
    Enclosing the directory path in quotes does not resolve the issue. I haven't come across any updates that might have impacted this behavior. Does anyone have an idea what could be causing this?
    Thanks.
  • Answer selected by David Otero at 10-04-2024, 08:31.
    David Otero
    • Apr 2024
    Thank you for the response.
    It seems that even if all the "\-s" are escaped to "\\-s", it still doesn't work: it indicates that regular expressions cannot be used in the path route.
    However, if I only escape "\\Logs" in the path, it works.
    Solution: logrt[C:\Programas\3. Version DEBUG PalStats con Grafico\\Logs\Actual\^\d{4}-\d{2}-\d{2}_\d{2}-\d{2}-\d{2}\.log,"ERROR",,,"skip",]
    It's a bit counterintuitive. It seems that in a minor release, someone wanted to improve the debugger by searching for \F, \L, \l, \N{name}, \U, or \u throughout the entire path, forgetting that regular expressions can only be used in the filename.
    Solved.
      • 4990
      \Logs maybe this one? try replacing all \-s with \\-s
      • David Otero
        • Apr 2024
        Solved.
          • 4990
          If it looks like bug, walks like bug, acts like a but, then it probably is a bug... https://support.zabbix.com/browse/ZBX you can report it and see what devs think of this...
