Hello.
I have followed https://www.zabbix.com/documentation...x/install/okta to setup SSO & SCIm with Okta. SSO works without any problems but SCIM setu, connection test, shows:
Error authenticating: message=Invalid JSON received from the SCIM server. Cannot parse the JSON. error=Unexpected character ('<' (code 60)): expected a valid value (JSON String, Number, Array, Object or token 'null', 'true' or 'false') at [Source: (String)"<!DOCTYPE html><html lang="en" theme="blue-theme"> <head> <meta http-equiv="X-UA-Compatible" content="IE=Edge"/> <meta charset="utf-8" /> <meta name="viewport" content="width=device-width, initial-scale=1"> <meta name="Author" content="Zabbix SIA" />...
running with curl shows a sign-in page code.
api_jsonrpc.php call works with the same token...
I'm stuck...
Lukasz
I'm stuck...
Lukasz
