Slack webhook proposal
  • carambitko
    • Apr 2024
    Hello, I would like to ask a question about Slack Webhook integration available at https://www.zabbix.com/integrations/slack
    The solution is working fine for me after upgrade to 6.0 but there is something strange at least for me in this integration.
    The script in MediaType shipped with this template creates and updates messages in Slack, but does not delete it after the problem was resolved.
    There is no need for a resolved problem to stay in Slack, even if it's updated to resolved.
    In this case manual intervention is needed in order to delete the resolved messages.
    Deletion of messages can be done very easy calling chat.delete API in Slack.
    Something more, between the update to resolved and deletion from Slack a sleep can be introduced, let's say 10 or 20 seconds, just for visibility.
  • evilmercer
    • Jun 2007
    I came across this looking for the same thing. I created a solution using the "alarm" mode and figured I would post it here for anyone else.
    Either edit or copy the slack media type. Then edit the script section as follows:
    In the final try block update the var Slack to have deleteMessage.
    var Slack = {
        postMessage: slack_endpoint + 'chat.postMessage',
        getPermalink: slack_endpoint + 'chat.getPermalink',
        chatUpdate: slack_endpoint + 'chat.update',
        deleteMessage: slack_endpoint + 'chat.delete'
    Update function handlerAlarm isEventResolve to use the new deleteMessage.
    else if (isEventResolve(params)) {
        fields.text = '';
        try {
            var channel_event_tags = JSON.parse(params.event_tags);
        } catch (error) {
            throw 'Cannot process event tags: ' + error;
        if (Array.isArray(channel_event_tags)) {
            for (i in channel_event_tags) {
                if (channel_event_tags[i].tag.includes('__channel_id_' + params.channel)) {
                    fields.channel = channel_event_tags[i].value;
                    continue;
                if (channel_event_tags[i].tag.includes('__message_ts_' + params.channel)) {
                    fields.ts = channel_event_tags[i].value;
        resp = JSON.parse(req.post(Slack.deleteMessage, JSON.stringify(fields)));
        if (req.getStatus() != 200 || !resp.ok || resp.ok === 'false') {
            throw resp.error;
    Here is the complete script.
    var SEVERITY_COLORS = [
        '#97AAB3', '#7499FF', '#FFC859',
        '#FFA059', '#E97659', '#E45959'
    var RESOLVE_COLOR = '#009900';
    var SLACK_MODE_HANDLERS = {
        alarm: handlerAlarm,
        event: handlerEvent
    if (!String.prototype.format) {
        String.prototype.format = function() {
            var args = arguments;
            return this.replace(/{(\d+)}/g, function(match, number) {
                return number in args
                    ? args[number]
                    : match
    function isEventProblem(params) {
        return params.event_value == 1
            && params.event_update_status == 0
    function isEventUpdate(params) {
            && params.event_update_status == 1
    function isEventResolve(params) {
        return params.event_value == 0;
    function getPermalink(channelId, messageTimestamp) {
        var req = new HttpRequest();
        if (typeof params.HTTPProxy === 'string' && params.HTTPProxy.trim() !== '') {
            req.setProxy(params.HTTPProxy);
        req.addHeader('Content-Type: application/x-www-form-urlencoded; charset=utf-8');
        req.addHeader('Authorization: Bearer ' + params.bot_token);
        var query = '{0}?channel={1}&message_ts={2}'.format(
                Slack.getPermalink,
                encodeURIComponent(channelId),
                encodeURIComponent(messageTimestamp)),
            resp = JSON.parse(req.get(query));
            throw 'message was created, but getting message link was failed with reason "' + resp.error + '"';
        return resp.permalink;
    function createProblemURL(zabbix_url, triggerid, eventid, event_source) {
        var problem_url = '';
        if (event_source === '0') {
            problem_url = '{0}/tr_events.php?triggerid={1}&eventid={2}'
                .format(
                    zabbix_url,
                    triggerid,
                    eventid
        else {
            problem_url = zabbix_url;
        return problem_url;
    function handlerAlarm(params) {
        var fields = {
            channel: params.channel,
            as_user: params.slack_as_user,
        if (isEventProblem(params)) {
            fields.attachments = [
                createMessage(
                    SEVERITY_COLORS[params.event_nseverity] || 0,
                    params.event_date,
                    params.event_time,
                    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source)
            var resp = JSON.parse(req.post(Slack.postMessage, JSON.stringify(fields)));
                throw resp.error;
            result.tags = {
                ['__message_ts_' + params.channel]: resp.ts,
                ['__channel_id_' + params.channel]: resp.channel,
                ['__message_link_' + params.channel]: getPermalink(resp.channel, resp.ts),
        else if (isEventUpdate(params)) {
            try {
            } catch (error) {
                        fields.thread_ts = channel_event_tags[i].value;
                        break;
                createMessage(
                    params.event_update_date,
                    params.event_update_time,
                    createProblemURL(params.zabbix_url, params.trigger_id, params.event_id, params.event_source),
                    true
                throw resp.error;
            fields.text = '';
            try {
            } catch (error) {
                        continue;
                throw resp.error;
    function handlerEvent(params) {
        var fields = {
                createMessage(
                    params.event_date,
                    params.event_time,
                throw resp.error;
            result.tags = {
                createMessage(
                    false
                throw resp.error;
                createMessage(
                    RESOLVE_COLOR,
                    params.event_recovery_date,
                    params.event_recovery_time,
                throw resp.error;
    function createMessage(
        event_severity_color,
        event_date,
        event_time,
        problem_url,
        isShort,
        messageText
        var message = {
            fallback: params.alert_subject,
            title: params.alert_subject,
            color: event_severity_color,
            title_link: problem_url,
            pretext: messageText || '',
            fields: [
                    title: 'Host',
                    value: '{0} [{1}]'.format(params.host_name, params.host_conn),
                    short: true
                    title: 'Event time',
                    value: '{0} {1}'.format(event_date, event_time),
                    short: true
        if (params.event_source === '0') {
            message.fields.push(
                    title: 'Severity',
                    value: params.event_severity,
                    short: true
                    title: 'Opdata',
                    value: params.event_opdata,
                    short: true
        if (!isShort  && params.event_source === '0') {
            message['actions'] = [
                    type: 'button',
                    text: 'Open in Zabbix',
                    url: problem_url
                    title: 'Event tags',
                    value: JSON.parse(params.event_tags).filter(function (e) { return !e.tag.includes('__') }).map(function (e) { return e.tag + ': ' + e.value }).join('\n') || 'None',
                    short: true
                    title: 'Trigger description',
                    value: params.trigger_description,
                    short: true
        if (params.event_source !== '0' || params.event_update_status === '1') {
                    title: 'Details',
                    value: params.alert_message,
                    short: false
        return message;
    function validateParams(params) {
        if (typeof params.bot_token !== 'string' || params.bot_token.trim() === '') {
            throw 'Field "bot_token" cannot be empty';
        if (typeof params.channel !== 'string' || params.channel.trim() === '') {
            throw 'Field "channel" cannot be empty';
        if (isNaN(params.event_id)) {
            throw 'Field "event_id" is not a number';
        if ([0, 1, 2, 3].indexOf(parseInt(params.event_source)) === -1) {
            throw 'Incorrect "event_source" parameter given: "' + params.event_source + '".\nMust be 0-3.';
        if (params.event_source !== '0') {
            params.event_nseverity = '0';
            params.event_severity = 'Not classified';
            params.event_update_status = '0';
            params.slack_mode = 'event';
        if (params.event_source === '1' || params.event_source === '2') {
            params.event_value = '1';
        if (params.event_source === '1') {
            params.host_name = params.discovery_host_dns;
            params.host_ip = params.discovery_host_ip;
        if (!~[0, 1, 2, 3, 4, 5].indexOf(parseInt(params.event_nseverity))) {
            throw 'Incorrect "event_nseverity" parameter given: ' + params.event_nseverity + '\nMust be 0-5.';
        if (typeof params.event_severity !== 'string' || params.event_severity.trim() === '') {
            throw 'Field "event_severity" cannot be empty';
        if (params.event_update_status !== '0' && params.event_update_status !== '1') {
            throw 'Incorrect "event_update_status" parameter given: ' + params.event_update_status + '\nMust be 0 or 1.';
        if (params.event_value !== '0' && params.event_value !== '1') {
            throw 'Incorrect "event_value" parameter given: ' + params.event_value + '\nMust be 0 or 1.';
        if (typeof params.host_conn !== 'string' || params.host_conn.trim() === '') {
            throw 'Field "host_conn" cannot be empty';
        if (typeof params.host_name !== 'string' || params.host_name.trim() === '') {
            throw 'Field "host_name" cannot be empty';
        if (!~['true', 'false'].indexOf(params.slack_as_user.toLowerCase())) {
            throw 'Incorrect "slack_as_user" parameter given: ' + params.slack_as_user + '\nMust be "true" or "false".';
        if (!~['alarm', 'event'].indexOf(params.slack_mode)) {
            throw 'Incorrect "slack_mode" parameter given: ' + params.slack_mode + '\nMust be "alarm" or "event".';
        if (isNaN(params.trigger_id) && params.event_source === '0') {
            throw 'field "trigger_id" is not a number';
        if (typeof params.zabbix_url !== 'string' || params.zabbix_url.trim() === '') {
            throw 'Field "zabbix_url" cannot be empty';
        if (!/^(http|https):\/\/.+/.test(params.zabbix_url)) {
            throw 'Field "zabbix_url" must contain a schema';
    try {
        var params = JSON.parse(value);
        validateParams(params);
        var req = new HttpRequest(),
            result = {tags: {}};
        req.addHeader('Content-Type: application/json; charset=utf-8');
        var slack_endpoint = 'https://slack.com/api/';
        var Slack = {
        params.slack_mode = params.slack_mode.toLowerCase();
        params.slack_mode = params.slack_mode in SLACK_MODE_HANDLERS
            ? params.slack_mode
            : 'alarm';
        SLACK_MODE_HANDLERS[params.slack_mode](params);
            return JSON.stringify(result);
        else {
            return 'OK';
    catch (error) {
        Zabbix.log(4, '[ Slack Webhook ] Slack notification failed : ' + error);
        throw 'Slack notification failed : ' + error;
