Problem when creating delayed trigger
  • markosa
    • Aug 2022
    • 107
    I have two trapper items, test and testclear, both use Numeric as data type and I'm trying to create trigger with info-level, this one triggers immediately, then second trigger which is dependant on first on, it should trigger after xx minutes. My problem is, when triggers are created, laterone is triggered immediately.
    Info-level trigger is(depends on warning level trigger):
    Problem: {TRIGGER.VALUE}=0 and last(/testhost/test)=1
    Recovery: {TRIGGER.VALUE}=1 and min(/testhost/testclear,10)=1
    Warning level has:
    last(/testhost/test)=1 and nodata(/testhost/testclear,5m)=1
    When I test with expression constructor that warning-trigger, it works OK
    How it is possible that warning level is triggered when there's no value within test or testclear item's?
    At the moment warning level trigger get's triggered when: item keys are changed or history and trends are cleared from those items.
    Zabbix 6.0.28 MySql
  • markosa
    • Aug 2022
    • 107
    Ok, looks like no one is using trapper items with delays, neither am I now. Solution was javascript which changes event severity and trigger action.
    Here's javascript:
    try {
        var params = JSON.parse(value);
        params.zabbix_url = (params.zabbix_url.endsWith('/'))
            ? params.zabbix_url.slice(0, -1) : params.zabbix_url;
        var evid = params.event_id;
        //evid.stringify(params.event_id);
        Zabbix.log(4, '[ Zabbix change event severity ] : ' + evid);
        var request = new HttpRequest(),
        body = {
            jsonrpc: "2.0",
            method: "event.acknowledge",
            params: {
                eventids: [evid],
                action: 12,
                message: params.msg,
                severity: params.new_severity
            auth: params.api_key,
        request.addHeader('Content-Type: application/json');
        //Zabbix.log(3, '[ Zabbix change event severity ] JSON: ' + JSON.stringify(body));
        var response = request.post(params.zabbix_url, JSON.stringify(body));
        Zabbix.log(4, '[ Zabbix change event severity ] Response: ' + response);
    catch (error) {
        Zabbix.log(3, '[ Zabbix change event severity ] ERROR: ' + error);
        throw 'Sending failed: ' + error;
    and required fields:
